Hello, as part of my job being the engineer/draftsman, I sometimes get request for "artistic representations" of assemblies. So what I do is I import an assembly into an IDW, then select the style as 'shaded'. How-ever I have a part in the assembly that represents (a cone shape) that is to represent gas exiting a nozzle. Well even as a transparent color, it still messes up the image. How can I remove the shading just on these cone objects? I tried to create a visible sketch and just project the cone objects lines (thinking I can just make the cone objects not visible and just leave the projected lines behind in the visible sketch). How-ever I think b/c the view is in a "Current View" that has perspective, it is not allowing me to project these line. Is there anything I can do to make this work?
Hi dvandoren,
See tip #1 at this link:
http://inventortrenches.blogspot.com/2011/06/autodesk-inventor-tips-from-around-web.html
Kudos to the guys at being Inventor for the tip.
I hope this helps.
Curtis
Well I guess that kinda works. The issue is that anything behind the clear object does not have there edge lines visible, it shows their color, but not the lines. I guess this will work for now until I figure out how to do this properly.
@Anonymous wrote:I sometimes get request for "artistic representations" of assemblies.
You could also look into placing Inventor Studio images into Sketched Symbols - perhaps even the Illustration type renderings.
Hi dvandoren,
Here's another possible solution for you:
I didn't actually step through this work flow, due to a busy Friday afternoon, but I think it might work depending upon your particular assembly. Post some screen shots and someone might have some other suggestions.
I hope this helps.
Curtis
Ok I figured it out. What I had to do was:
-Open assembly
-Create x2 new Views
-In view1 hide everything but the "what to be just outlined" objects, in view 2 hide "what to be just outlined" objects
-Create new position, but dont move anything
-Save, close
-Open Drawing
-Place new view as view2
-Use "Overlay View" tool, select position1, select as view1
and there you have it.... thanks for the help guys!
