Anyone have any ideas why this would happen?? See below..
I have a View Rep set up so that only my connection points are visible.
But when I place a drawing view (valve_vis.png), my valves stay visible for some reason.
Solved by cwhetten. Go to Solution.
Hi doubleA26,
If you edit the drawing view and look at the View settings under the Representation area, you'll see an Associative checkbox. If that is unchecked, does checking that box resolve this?
I hope this helps.
Curtis
Good morning Curtis, the box is checked. I can uncheck, toggle visibility on/off, but the valves still stay visible no matter what
I have a hunch that the original STP file that was downloaded (before my time here) is the culprit. I will try re-downloading the file and have another go at it...
Is the valve file a surface model or a solid? I have noticed this behavior with surface bodies--they don't seem to be controlled by view reps (in the drawing view, anyway). If they are, find the browser node for these parts in the drawing view, right-click, and uncheck "Include".
Good afternoon cwhetten. I've looked at my browser nodes and I do not have any surface bodies on this particular part. However, this part was derived from an assembly that was imported as such from a STP file.
Still digging around on this one. It's bugging me...
Its not an iassembly is it?
@doubleA26 wrote:...this part was derived from an assembly...
There's your problem right there. When a part is derived from an assembly, any drawing views of that part will display the part no matter it's visibility status. This is a known bug.
The only way I have been able to get around it is to derive a new part from the part derived from the assembly. In other words, take your assembly file > derived to a part (maybe break link to original assembly) > derive to another part. I don't remember if it is necessary to break the link to the original assembly or not. I don't think you have to, but if you can't get it to work, try breaking the link.
mcgyvr - it's not an iassembly.
cwhetten - thanks for the info, noted for the future. I didn't know about the bug. This explains a lot.
I was able to find the original STP file and imported it as a SMB part and I'm now able to get the visibility to act like it should.
Thanks all for the help! Have a good day...
When I said it's a "known bug", I didn't mean to imply that you should have known about it. I meant that it's an issue known to Autodesk. I guess it has been around for a while (I recently saw some posts about it from version 2010), but I didn't know about it until a couple of months ago.
