Afternoon
Is it possible to have the sketch I use in the part, visible in the drawing in order to dimension from?
I know it sounds insane, because I can dimension from the part, but the part can change based on parameters, however, the sketch remains the same and I need to reference to a center point of a specific feature.
Solved by JDMather. Go to Solution.
Yes you can
Expand the Extrusion, cut, revolve etc .... go to the Sketch1 (or whatever number it is in the part) then check on Visibility.
Another option is when you are doing the sketch is to Project Geometry and click on the item you'd like to reference.
Mike
Hi Mike
What I am looking for is to have the part SKETCH visible in the IDW drawing?
Ummm I don't think that is possible,
however the features should all be there for you to detail/dimension too ..can you post an idw for us to review?
Yes, the sketch can be made visible in the drawing. You can also Retrieve the Dimensions.
Hi Nishan,
Please share the files here. The forum experts can help take a look to understand the part sketch visibility issue in the drawing. It could be a bug.
Many thanks!
