i have this doubt.
I have inserted a part list table in a drawing.
Then i realize that i want to edit the Part List Table style and i will create a new column for the material with colum chooser.
My Part List Table in the drawing doesn't update.
Is there a way to update it without delete it and insert it again?
Thank you all
bs
Solved by johnsonshiue. Go to Solution.
Hi! After you finish updating the Parts List Style, go to Annotate tab. Look at the far left and you will find Format section. Now, mouse-pick the Parts List table on the sheet you would like to update. Next, go to the Format section and select the updated Parts List style from the dropdown list in the Format section. The Parts List will be updated based on the selected style.
Let me know if it works for you.
Thanks!
Nice tip Johnson! Thank you!
An auto-update it would be easier or an update button, but it works!
Thank you!
