Hi Sirs,
Anybody knows what is happenning wuht the part list Attached????
I Have reinstalled inventor 2011 EN but issue is still there.
3 machines runs wel, 1 runs bad
Regards
Solved by alessandro.gasso. Go to Solution.
Please, try the following.
Menu Tools > Options > Add-ins.
Select ESKD Support in the Add-In manager list and uncheck the box “Loaded/Unloaded” and “Load on Startup” in the Load Behavior section in the lower part of the Add-In Manager dialog.
I hope it helps.
Kind regards,
Alessandro
Hello, thanks for the solution but is there any permanent solution. I have to change this every time I create a new drawing.
Hi Shivam,
It looks like the change you made in Add-In Manager did not stay. This may be related to your Windows User Profile. Are you at a school? Do you run Inventor as Admin?
Many thanks!
