I'm designing a part that in Autodesk Inventor 2013 that is constructed from several layers laminated together. I have 4 layers:
F (front)
M1 (middle, variation one)
M2 (middle, variation two)
B (back)
The final solid will lhave 17 layers laid out like this:
F | M1 | M2 | M1 | M2 | M1 | M2 ... | B
I currently have a part file containing
F | M1 | M2
What's the best way to create this solid if I want to a) keep all instances of M1 and M2 in sync, and b) make it easy to work on all 4 layers. Do I have to export F, M1, M2, and B as individual parts and import them into an assembly or can I keep them in one part file? I really like the ability to be able to work on all the solids at the same time because they're visually dependant on each other.
Thanks!
Solved by tallhamn. Go to Solution.
Hi Blair,
I have an IPT part file with 3 solids right now; it contains F, M1, M2 mentioned above.
I need 8 x M1 and 7 x M2. Can you please elaborate?
Marcus
You can have multi instances of the same solid. It would have be labeled different. It may be the same material but I doubt it can be the same item. This would then become an some form of assembly. I guess I miss understood what you were really trying to do.
