I just had to reload IV2012 on a new SSD Drive, and now the placemnet order of my constrains are missing. As in what part is constraint 1 and which part is consrtaint 2 for each constraint. I can't find the setting to turn this back on, been way too long since i had to worry about this setting.
thanks
msk
Solved by JDMather. Go to Solution.
Are you referring to Assembly constraints or to Sketch constraints?
So, was that the solution?
