Hallo!
Ist es möglich aus der Inventor-VBA auf die Nummergenrierungssystem von Vault zu zugreifen. Ich will die Parts in einer Baugruppe abspeichern und automatisch die richtige Nummer, die man aus Vault bekommt, vergeben.
Is it possible in Inventor-VBA to get the Partnumber (Assembly) from Vault?
Danke!
Hi! Is "dfdf" in this case an overridden browser name? Or, it is the file name with Part Number: 000014233?
Thanks!
Hi mecahnikus,
If you open the part file and and look at the browser do you see the file extension listed? If you do not, and you go in and manually reset it as shown in this image, does that then fix the issue?
You might also need to use the Rename Browser Nodes tool to fix the names in the assembly:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-85EAA751-D69B-454D-9871-251D90B20F06
I hope this helps.
Curtis
dfdf and 000014233 there are file names and Part Number. 000014233.ipt --> "000014233:1"
If I Login by Vault, I can get the file name (=Part Numer) from Vautl, if I save dfdf.ipt (see picture) . This name 000014233 will be generate automatically by Vault. I want obtain this file name in VBA but I don't know, how!
