Inventor Forum
Part balooning
3 REPLIES 3
BartS83
288 Views, 3 Replies
Part balooning
In my journey of becoming an Inventor expert, i'm encountering a small challenge which I can't seem to find the answer of on the internet. So that's why I'm hoping to find an answer here... 🙂
I'd like to balloon a part in a drawing, but when I try to do that, I shows the assembly number in which the part is placed. I've seen some posts about changing the assembly to a 'ghost' part, but that is not what I want.
There seems to be one opportunity to get the settings right, and that is when i'm ballooning the very first part. When i do that, I get a screen with 'BOM properties' In that screen, I can set the BOM View to 'Parts only'. But when I want to set these settings later, I can't find these setting anymore.
Is there anybody who can help me with this?? I'd be very appreciated!!
Thanks in advance!!
Kind regards
Bart Sijm
ZTI Mechatronincs
Netherlands
3 REPLIES 3
mcgyvr
in reply to: BartS83
See if this helps you..
http://grabcad.com/questions/tutorial-adding-sub-assembly-parts-to-an-assembly-parts-list
Then if you place the subassembly into its own sheet and use that base view for the parts list on that sheet you don't have the problem either.
Personally though...I ALWAYS use a separate drawing for each part, each subassembly, each assembly,etc... and I would NEVER do a ballooned bom like you are trying to do.. Yes people do it for various reasons but its almost always the wrong way to do it.. Again my personal opinion here..
There are a few reasons why..
#1-If any of the parts/subs,etc.. are reused then you don't have to keep recreating the drawing over and over again to detail that for that specific project.
#2-If that one drawing gets corrupt you have a lot of time into it and ALL is lost.
dlmsdm1
Agree with mcgyvr, separate drawing for each assembly/part is the only way to go. As you build a library of parts, the less you have to re-create for every job.
But if you have to do it your way, you need to delete the parts list and balloons and start the balloon process over.
salariua
Bart,
You need to delete all balloons AND Parts List table. When you try to place a balloon or the table again it will prompt for the structure level you want.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
