Does anyone know if you can display Part Area in a Collumn in a Parts List on an idw?
P
If it's simple length x width just create a parameter and export to custom iproperty.
You may possibly be able to extract the sheet metal area.
But I'm not sure about the total surface area directly.
This may be possible through ilogic or vba.
Yes thanks thats what I thought but just wanted to check.
I can get it if its sheet metal part yes but not all the parts are sheet metal.
Thanks.
Try the following: (In this case, the data displayed in the parts list is m²; playing around with the units will allow you to get the unit of measurement you want.)
Create a new user parameter called "Area", set units to m.
Create an iLogic rule, copy and paste the following:
iProperties.Value("Custom", "FlatExtentsArea")=SheetMetal.FlatExtentsArea
Area=SheetMetal.FlatExtentsArea/1000
iLogicVb.UpdateWhenDone=True
In Document Settings, set linear dim precision to 2.12 (Units tab), then set the base qty to Area (BOM tab).
The unit of measurement displayed in the parts list will be m (as opposed to m²), however the value will give you the area in m².
Hope this helps!
