Inventor Forum
PARAMETRIC TEXT BOX IN SYMBOL
1 REPLY 1
SPANGDAHLEM
516 Views, 1 Reply
Hi..
I’ve been looking for a way to make my symbols a little more friendly. I need the box around the text re-size itself based on how much text I use. Got any help?
1 REPLY 1
mpatchus
in reply to: SPANGDAHLEM
This method isn't "automatic" but it does allow some relatively easy manual manipulatiom.
Create a text box for your symbol. After entering your text, offset the textbox boundaries and apply a dimension.
Now when you edit the text, simply grab the corner of the textbox and the outline will follow.
The result... granted its still manual....
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
