Inventor Forum
Parameters Where are they?
4 REPLIES 4
Cadmanto
307 Views, 4 Replies
If I have a part with a variety of features and associated dimensions, I should be able to go to the manage tab and select "Parameters" and see those dimensions in the dialog window right?
If there is no (+) next to the "Model Parameters" how do I get the list to populate with the dimension variables?
Best Regards,
Scott McFadden
(Colossians 3:23-25)
4 REPLIES 4
japike
in reply to: Cadmanto
Are you using any parameter filters? Look at the lower left of the parameters window.
Peace,
Jeff
Inventor 2022
Cadmanto
in reply to: japike
Not intentially.
This is how it comes up when I bring up the parameters.
What should it be set to as a default?
Best Regards,
Scott McFadden
japike
If you click on the upper left icon (the one with the green check mark), you will get a drop down menu - all should be checked.
Peace,
Jeff
Inventor 2022
Cadmanto
in reply to: japike
Thank you.  Once I selected the "All" they showed up.
Best Regards,
Scott McFadden
