Hello everyone,
first of all, thanks in advance for your time.
I have a part, which is configurated from a formular that shows up when the part is opened. As soon as I change a parameter in the formular, the part is automatically updated, which I don't want to happen. The best option would be that as I close the formular, all the parameters would be updated. Another option would be to update them manually, by clicking in the "Local update" button, after I close the formular. I have tried everything I know even with iLogic, but nothing seems to work. Any ideas?
Kind regards,
CARLOS CARO
Solved by CCarreiras. Go to Solution.
Hi Carlos!
If you're changing the parameter in Fx table, you can delay the update unselecting "Imediate Update"
If you're using a Form, use the buttons "ok- Cancel - Apply". The parameters only update when you press the apply or ok, not after.
Regards.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
Hello Carlos,
in fact, I am using a Formulare, but I don't know how to attach the Yes-No-Apply buttons in there, can you explain it please? But that's exactly what i want!!
CARLOS
Hi Carlos!!
That was very useful. Thanks a lot.
Kind regards,
CARLOS CARO
