Inventor Forum
Parameters update from formular with delay, not automatically
4 REPLIES 4
354 Views, 4 Replies
Hello everyone,
first of all, thanks in advance for your time.
I have a part, which is configurated from a formular that shows up when the part is opened. As soon as I change a parameter in the formular, the part is automatically updated, which I don't want to happen. The best option would be that as I close the formular, all the parameters would be updated. Another option would be to update them manually, by clicking in the "Local update" button, after I close the formular. I have tried everything I know even with iLogic, but nothing seems to work. Any ideas?
Kind regards,
CARLOS CARO
4 REPLIES 4
CCarreiras
Hi Carlos!
If you're changing the parameter in Fx table, you can delay the update unselecting "Imediate Update"
If you're using a Form, use the buttons "ok- Cancel - Apply". The parameters only update when you press the apply or ok, not after.
Regards.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
in reply to: CCarreiras
Hello Carlos,
in fact, I am using a Formulare, but I don't know how to attach the Yes-No-Apply buttons in there, can you explain it please? But that's exactly what i want!!
CARLOS
CCarreiras
Hi!
Edit the form;
Chose the button's  behavior you want to use.
Regards.
CCarreiras
Hi Carlos!!
That was very useful. Thanks a lot.
Kind regards,
CARLOS CARO
