I am trying to use iLogic Form in Inventor.
I used "Row" in Toolbox. And I pulled my parameters in sequance.
But when I run this Form, the parameters are not in sequence which I defined.
Does any body know how to fix it?
Is it some mistake I made or is it Inventor issue?
I am trying to add some pictures for you to understand my issue.
Hi zdhrichard,
I think if you employ some Groups in your form, you'll get what you're after. See these links:
http://forums.autodesk.com/t5/Inventor-General/iLogic-form-format/m-p/4366143#M479584
Edit: Fixed the link above (thanks Mike!)
Also see the last video on this page:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-656A8515-BAD9-419D-95D0-E1775920C273
I hope this helps.
Curtis
