I have the following problem:
I have created a form in which I need to see the volume value. For that I created a User Parameter that is set to be equal with part's volume:
Volume=iProperties.Volume
What I don't like is that the precision for the parameter is too long and I can't change it...
I changed the precision in Document Settings and also for the parameter itself in the Parameters window, but these changed don't affect what is the form.
Any solution? A precision of 1.1 would be good for me.
Alexandru
Solved by jletcher. Go to Solution.
Unfortunately it works only if the Units are set to meter in Document Settings. I really need to be mm there. And if so, it still displays too many figures. Please check this in the attached part1 from my first post.
Regards
Alexandru
As James mentioned, here is screen capture to help:
The top one is yours, the bottom one is the iProperties.
