Inventor General Discussion
Valued Contributor
j_berry
Message 1 of 6 (321 Views)
Parameter Not Rounding Correctly
321 Views, 5 Replies
10-07-2013 11:08 AM
I'm getting unexpected results using "round( )" in the parameters table. File attached (Inventor 2014). Details below.
width = 35.125
end_result = round(width)
Nominal value for "end_result" is 35.039370. Why is this not rounding to exactly 35?
It's probably a units problem.  For whatever reason, the round( ) function expects a unitless value, and returns a unitless value.  So, if width and end_result are in mm, you will have to write your function like this:
round( width / 1mm ) * 1mm
The ceil( ) and floor( ) functions suffer the same ailment.
Cameron Whetten
Inventor 2014
Please click "Accept as Solution" if this response answers your question.
cwhetten
Message 2 of 6 (315 Views)
Re: Parameter Not Rounding Correctly
10-07-2013 11:13 AM in reply to: j_berry
Cameron Whetten
Inventor 2014
Curtis_Waguespack
Message 3 of 6 (311 Views)
10-07-2013 11:16 AM in reply to: j_berry
Hi  j_berry,
See this link for further information:
http://forums.autodesk.com/t5/Autodesk-Inventor/parameter-rounding-up-to-nearest-fractional-part-of-...
If that helps, you might give  cwhetten a couple of kudos for the well written explanation. :smileywink:
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
New Member
brucejwheeler
Message 4 of 6 (246 Views)
10-16-2013 08:02 AM in reply to: j_berry
Is there a way to "round up" or "round down"? This would give a conditional number.
If I round()*1, I may get a decimal number (less than 1). My preference would be to rounddown to recieve a lwer whole number.
Valued Contributor
mikejones
Message 5 of 6 (240 Views)
10-16-2013 08:09 AM in reply to: brucejwheeler
You'll need to use FLOOR() or CEIL() to round up or down respectively
Mike
Autodesk Certified Professional
New Member
brucejwheeler
Message 6 of 6 (239 Views)
10-16-2013 08:15 AM in reply to: mikejones
Thanks Mike this works!!
