Inventor General Discussion
Valued Contributor
nannerdw
Message 1 of 3 (266 Views)
Accepted Solution
Parameter in idw text, (Units?)
266 Views, 2 Replies
11-29-2012 11:48 AM
I have a model in imperial units with the parameter: Pin_Dia = 7mm.
Now I'd like to use this parameter in a text field on a drawing, but its value will only display in inches.
(I don't know if it's called a field in Inventor, at least that's what the equivalent feature is called in AutoCAD.)
I managed to fake it by creating a new parameter in inches: Pin_Dia_Metric = Pin_Dia * ( 1 ul / 1 mm ).
Now this shows up in the text dialog box as "7.0 ul."  It still displays correctly, since the text field only shows the numerical value, but I really don't want to clutter up my Parameters list with a bunch of duplicated values for metric conversions.
Is there a way to change the units for just this one text field?
-Using Autodesk Inventor Professional 2012
*Expert Elite*
JDMather
Message 2 of 3 (260 Views)
Re: Parameter in idw text, (Units?)
11-29-2012 11:58 AM in reply to: nannerdw
What are your document units?
(Tools>Document Settings >units)
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Valued Contributor
nannerdw
Message 3 of 3 (245 Views)
11-29-2012 12:46 PM in reply to: JDMather
I added a metric standard to my drawing, and that fixed it.  Thanks.
Announcements
Need installation help?
