Inventor Forum
Parameter driven tolerances?
1 REPLY 1
rchiccarine
442 Views, 1 Reply
I would like to feed the tolerance of some parts with parameters, but can't figure out how.  Basically the parameters are coming from an excel spreadsheet.  It calculates the limits based one the diameter.  It might be 1.000/1.001 or 2.000/2.004.  I can set the two parameters to the upper and lower limit, or the lower limit and variance.  But, I do I use the parameter to set the tolerance on the part?
1 REPLY 1
rchiccarine
in reply to: rchiccarine
I figured it out, had to add an iLogic rule:
Parameter.Param("d8").Tolerance.SetToDeviation(0.0, [parameter_name]*2.54)
