Can Dynamic Simulation drive multiple variables with a single parameter?
In the following example, the variables len_A and len_B are driven by size.
The parameter "size" varies from .8 to 1.2 (currently I have size parameters in a Multi-Value List).
Is there a way Dynamic Simulation can drive the "size" parameter to animate the assembly?
I plan to use Dynamic Simulation's Output Grapher to Plot a Trace of the triangle's apex as A and B vary in length.
The example assembly is attached.
I am asking for your help because I have looked at many simulation and animation tutorials and haven't found how to do this. I appreciate your suggestions.
Solved by henderh. Go to Solution.
You should state what version of Inventor you are using (especially when you are using an old version) as you are otherwise likely to get solutions you can't open.
Hi kmckenney,
Dynamic Simulation treats all bodies as rigid, so it cannot vary the size of a component / sketch dimension.
But, we can accomplish what you're after, if we break up a sketch line component into two components in a flexible sub-assembly...similar to actuator. You would drive the length in a prismatic joint using the input grapher, using imposed motion of the position.
I attached an example assembly for you.
Hope this helps! Please let us know if you have any further questions, comments or suggestions.
