Inventor Forum
Paint ommission in IDW
4 REPLIES 4
345 Views, 4 Replies
In my IDW (IV R11) I have a brazed assembly of parts. The assembly gets painted but certain sections/ areas are to be masked off and be free of paint. In ACAD I would draw a hatch to indicate what areas are free of paint and callout a leader indicating this. What method would you use to do this in Inventor IDW?
4 REPLIES 4
JDMather
Sounds like you could use the same method in Inventor.
Can you post an example set of files.
Click on the red view boundary to make active and hit s on the keyboard. Sketch and hatch your area (project geometry to locate the area - Done).
i just figured it out. Sketch in IDW and hatch region. Never had a instance where I needed to do this. Thanks anyway.
mcgyvr
I model the unpainted/masked section in the part files. By creating a sketch for the unpainted area and using the split command. Then I can apply a different color to that area. Then in the drawing you can show that area easily.
I thought about doing something like that. I'll keep that in mind since we have a lot of instances that I'll need to do this at this new place im working.
