When I do a detailed set of drawings I first start with the overall and ballon the part showing the BOM. The following pages will reflect the detailed parts balloned on the first page. Is there a way, without haveing to manually type in the BOM, to reference which page this detail is on in the BOM?
Thank you for your help
Welcome to the forum.
The short answer is "No". This might be able to be done through iLogic.
The other thought is you could tie a custom property in with the parts and have this property show up in the BOM.
Are you looking for thie sheet number to be a seperate colulmn in the BOM?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Thank you for the reply.
Thank you, I am just an Intern right now with a company but would like to help better the drawings they provide.
Yes I would like for it to be a seperate column. As of now I just create a column and title it and put in the page number I located the detaild part. I was just hoping for some possible way to do this. Would the be a possibilty of writing something through the VBA editor to create a function for this?
Short answers are never as exciting. Specially if it is No haha
Not sure if I quite understand what you mean. As of now I do not have an automatic way of reflecting the page number in the Bill of Materials for detailed drawings. Right now if I change anything in the drawing set then I have to manually change the page number in my BOM.
VBA, iLogic very similar. I am not a guru in this area, so I am the wrong one to ask on that.
That is what I was thinking might be your only option.
Ok thank you. That at least helps to narrow it to a special area. I am no expert in that area either. Hopefully someone has tought of the same idea and maybe has a program wrote for it. One can only pray.
I need to keep the Item number since that is how I would ballon the item.
I will need to do some research and figure things out on how to write macros. I have not done such a thing and may look in to it more. Thanks
@Anonymous wrote:...The following pages will reflect the detailed parts balloned on the first page. ...
Hi almeitl,
I have a couple of questions about your workflow:
I hope this helps.
Curtis
Hi Curtis,
The answers to your questions would be:
1. Most commonly there are multipul parts to one page for the details.
2. Ususally they are not used in other drawings. Each part is used in that specific assembly only.
