Inventor General Discussion
Active Contributor
kdlklm
Message 1 of 3 (314 Views)
pack and go problem
314 Views, 2 Replies
07-22-2011 12:46 PM
after doing a pack and go, to transfer my project from my old machine to my new machine. it continuously gives me this error message when I open up the file. I have attached a screenshot.
Hi
I think your Content Center is not properly maped
try this
1-pack and go option  :skip library, checked .click ok let the process run and close
2-in your old machine go inventor application option, Content Center tab, find the location of the library
3-copy the folder and transfert it to the new machine in the folder indicated in application option
other workflow
 you can grab the same folder and paste it in library folder who is set  up in the project option
good luck
Valued Mentor
yannick3
Message 2 of 3 (295 Views)
Re : pack and go problem
07-22-2011 03:49 PM in reply to: kdlklm
Hi
try this
other workflow
good luck
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
New Member
josemireigada
Message 3 of 3 (121 Views)
Re: pack and go problem
10-09-2012 03:03 AM in reply to: kdlklm
Hello!
Another problem with the Pack&Go
When I Pack and Go some models with parts developed with Frame Generator and I want to make changes with Edit in Frame Generator I cannot find the shapes in the Content Center.
Thanks in advance.
