Have you tried going back to the original un-P&G'd assembly and tried saving that ? What was the outcome ?
Is the error repeatable for the affected assemblies ?
Have you tried Re-build All then saving before P&Ging
(The next sounds crazy - but there is madness in my method )
Have you tried Update Mass Properties, then saving before P&Ging ?
Updating Mass Properties forces Inv to change the properties on more files and therefore forces it to save more. This might
highlight the problematic file before P&Ging.
When you get an error message select the Copy to Clipboard button in the bottom left hand corner. Then paste that into either
Notepad and save or paste it into E-mails / postings. The error message has more data hidden behind it which can be helpful -
particularly to Adesk - in solving this issue.
Which template files are you using, are they native Inv8 or migrated from an earlier edition ?
"You can fool some of the people all of the time, and all the people some of the time, which is just long enough to be president of
the United States." (Puckoon) {ibis}
Duncan
"Humour ... is one man shouting gibberish in the face of authority, and proving by fabricated insanity that nothing could be as mad
as what passes for ordinary living."
(Terence 'Spike' Milligan K.B.E., 1918-2002)
www.autodesk.co.uk/inventorjobs
wrote in message news:4860358@discussion.autodesk.com...
Sorry for vagueness.
Most P&G's do save but when they don't there's an error message similar to the following:
! Erros detected while writing segment Am Graphics Segment in database.
! Error detected while saving object of type AM x Node Override Attribute.
! The database in (main assy number) could not be saved.
Version is IV8
Using main assembly to open the P&G file.
I copy to single path and include linked files and don't skip library files.
And there are holes in the sky where the rain gets in but the holes are small, that's why rain's so thin! (Same chap)
