Inventor Forum
Outline of Invisible Assembly Components
5 REPLIES 5
750 Views, 5 Replies
Is there a way to mouse over components in an assembly that have their visibility off and see an outline of where the component is to more easily find the invisible component in the assembly?
5 REPLIES 5
cwhetten
You can find them in the browser.  Invisible parts will have their icons grayed out.
-cwhetten
in reply to: cwhetten
Yes, but with larger assemblies I don't know which greyed out (invisible) component is which necessarily, and can spend a bit of time turning components off and on to find the component I meant to turn back on.  Do you know of any way to get an outline of them in the assembly when you mouse over them or single click on the in the browser?
cwhetten
You can try toggling the Enabled option instead of using Visibility.  Parts turn transparent so you can see through them and work through them, but you can still see where they are on the model.  Also, when you highlight them in the browser, they light up in the graphics window.
The disadvantage: you can't make use of the View Reps functionality with Enabled/Disabled status (as far as I am aware).
-cwhetten
cwhetten
Edit on the above post:  I was wrong.  Design view reps can control the Enabled / Not Enabled status of parts.  I really should use the Enabled status more often, since it could really come in handy.
-cwhetten
Thank you... I will try out the Enable instead.
I'm not sure why the visible parts in the assembly highlight but the invisible ones don't...?  Other programs have that functionality.  Another one for the wish list I suppose.
