They are assuming a set amount of loss through the drive train. There is
usually a very big difference between production cars and modified racers.
The numbers I got from putting in my numbers are a bit low (about 30 HP)
compared to my dyno results.
I haven't done any full blow car frames but I did do a go kart frame for a
friend. I used workpoints and 3D sketches as it was all tubular steel
construction.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Kent Keller" wrote in message
news:4DA7911DC1A1481DCDCB5CAB352D013B@in.WebX.maYIadrTaRb...
> I have no idea what any of this has to do with Inventor, but I can't help
myself.
> Hopefully I have enough brownie points built up that I won't be in too big
of doo doo.
> Hi Anne 8^)
> Seemed pretty close to me. 8.6 seconds 2000 lbs 621.47 HP at the wheels,
and about
> 807.92 HP at the flywheel.
> That is about what I had always figured I had??
> I know... lets bring this back around... What method do most people
that have drawn
> tube framed cars used in Inventor? Master sketch? Fixed workpoints and 3d
sketches? or
> surfaces to extract the 3d path or ??
> Kent
> Member of the Autodesk Discussion Forum Moderator Program
> "rllthomas" wrote in message
news:f150bf9.8@WebX.maYIadrTaRb...
> > Horsepower Results - 1/4 Mile Method
> > Your Mustang Cobra weighs about 3430 pounds and can complete a 1/4 mile
in about 13.4
> seconds. That means that you've got about 281.75 HP at the wheels, and
about 366.28 HP at
> the flywheel.
> > Close, its a 320 HP engine.
