Hi all,
This is the second time I encounter this:
NONE of the Origin planes of the main assembly and its children are shown.
Is this a setting in options?
Please help
Thank you
Inventor 2014 with sp 2
Solved by JDMather. Go to Solution.
View\Object Visibility
Create a new View Representation, turn on the planes using the above and save. If they still aren't showing, they may have been turned off at the subassembly or part level, you will need to activate the ones you want to see and turn the visibility back on.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I tried it after you sent your reply.
I actually don't see the origin folder of the main assembly nor those of the children,
Please see attached snap shot.
Thank you
Click on Browser Filters.
