Can you move them up and down after they have been created?
I created whole bunch of View Representations but when I try to improve the "sequence" of views:
add an extra one right under the other or move them around it seems like Inventor does not give me the option of doing that.
Solved by skyngu. Go to Solution.
copy and delete untill you have perfect sequence.
No you cannot..That would make WAY too much sense.
You can however do the copy dance with them.. When you copy one it moves to the bottom.. If you get it right then you can rearrange this way.
Yes, it would make so much sense that I cant even see how it is possible that we dont get that option.
Thanks guys.
