Inventor Forum
ORDINATE SET DIMENSION - PICKING INTERSECTION POINT
2 REPLIES 2
nivenl
2252 Views, 2 Replies
I can use regular dimension to pickout intersection point between two lines, but I can't seem to find a way doing it using ordinate dimension.
Imagine two line at an angle of 120 degree, and there is a fillet between them. I want a dimension to that theoretical intersection using ordinate set.
All feedback are appreciated.
Thanks.
2 REPLIES 2
jddickson
in reply to: nivenl
If you absolutely have to use ordinate dimensioning (I would not recommend using ordinate dimensioning in this case) you could always attach a sketch to the view and make a point where that intersection is located. As long as you project your geometry and dimension off the part in view it will always keep the correct location.
I hope this helps.
Curtis_Waguespack
in reply to: nivenl
Hi nivenl,
Try this:
  • Start the ordinate dimension tool, and select the view
  • Zoom in real close on the filleted corner
  • Hover over one end of the arc until you see a green dot (but do not click)
  • Hover over the other end of the arc until you see another green dot (but do not click)
  • Drag toward the intersection and you should see dotted, tracking lines
  • Click to set the point when you see the yellow dot at the intersection
I hope this helps.
Curtis
