I can use regular dimension to pickout intersection point between two lines, but I can't seem to find a way doing it using ordinate dimension.
Imagine two line at an angle of 120 degree, and there is a fillet between them. I want a dimension to that theoretical intersection using ordinate set.
All feedback are appreciated.
Thanks.
Solved by Curtis_Waguespack. Go to Solution.
If you absolutely have to use ordinate dimensioning (I would not recommend using ordinate dimensioning in this case) you could always attach a sketch to the view and make a point where that intersection is located. As long as you project your geometry and dimension off the part in view it will always keep the correct location.
I hope this helps.
Hi nivenl,
Try this:
I hope this helps.
Curtis
