Inventor Forum
Ordinate Dim Help
5 REPLIES 5
jacornej
345 Views, 5 Replies
Ordinate Dim Help
I am running Inventor Professional 2011 and I have horizantal ordinate dimension, and what I need is to have Text above the Dim line and dimensions beneath it.
For example like this
XXXX
DIM
Right now I have them like this
XXXX_________
DIM
Is this even possible? Any help is appreciated, Thank You
5 REPLIES 5
in reply to: jacornej
If you could post an example of what you have, it would be helpful.
jacornej
I'm trying to get it to look like the second one
I played around with the dimesion style, I don't think you can do what you want.
jacornej
Yeah I've been playing with it all morning. Couldn't figure it out. Thanks anyways.
mpatchus
Closest I could come by using underlined text above the <<DIM>>
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
