I made comments about not being any ordinate dimensions shown on that drawing.. I have edit this post because... Now I see your small drawing. I didn't zoom all the way out.
Edited by: mcgyvr on Sep 4, 2009 12:09 PMI realize this thread is ancient in terms of inventor, that said this is for anyone who more recently has had a similar issue. I often draw revolved parts with various changes in diameter. This requires a lot of dimension lines and detail views to illustrate the smaller geometry clearly. My solution to this is to do a half section view of the revolved part, hide the geometry on one side the center line and scale up the section view. While I have not found a way to change the ordinate dimension tool to represent a diametric value when the origin is placed at the center, I can explain a similar method that should prove just as useful.
1. Select the general dimension tool
2. Select the geometry that you would like the extension line to start from
3. Select you center line (draw a center line first if you have not already)
4. Right click and select dimension type from the drop down menu
5. Select linear diameter from the second drop down menu
6. Drag you dimension to your preferred location
I hope this helps.
Ok, so I have a cross section of a turned part, my zero point is the axis, I want to dimension start & end points of arcs, intersections etc.
The PDF attached, I have had to manually change from rads to diameters, I was hoping to RMB, and get the dimension type option (radius or diameter)
Hi! I am not sure if this is related. Here is a frequently overlooked option in Tools -> App Options -> Drawing -> Dimension Type Preferences. You may select the desirable types so that you don't have to keep changing the type when creating a new dimension.
Many thanks!
