I was playing around with that orbit wheel zooming in and panning around afterwad I clicked on right side view from the cube at the top right and it didn't give me an exact side profile view. I see a profile view at somewhat of an angle now.
Anyone know how to reset this?
Solved by Curtis_Waguespack. Go to Solution.
Hi jimmy760,
If you right-click on the View Cube and choose Orthographic, does that fix it?
Edit:
I just played around with the Navigation Steering Wheel to see if I could determine what you did, and noticed that the "Look" button automatically switches you from Orthographic mode to Perspective mode, so setting it back to Orthographic mode via the view cube should be the ticket.
I hope this helps.
Curtis
Click on view face and select a face that you want to be the front or top view.
Then right click on the view cube and set current view as front or top.
I really wish everyone would include screenshots with their posts. That helped a ton. Thanks!
