When i dobble click at an .ipt file, autodesk inventor open, but when i wont to open an other .ipt file, a new autodesk inventor program opens, insted of just a new fan. Can someone plz. help me.
Welcome to the forum.
If you are opening these files up from windows explorer, I would advise against that. I always open up my session of Inventor first, then using the open dialog within the session I open my files. Try that and you should be able to open up many files in one session.
Side note, if your member name is part of your serial number, that is not a good idea. That opens up the possibility of the code getting stolen.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
