Inventor General Discussion
Member
belsebuth
Message 1 of 17 (8,935 Views)
Accepted Solution
opening inventor 2014 files with Inventor 2013
8935 Views, 16 Replies
09-19-2013 12:04 PM
One of our customer has inventor 2013 and I am working with inventor 2014.
I would like to know if there is anyway for my customer once my job is done to be able to load the Sub assembly with his software and be able to work with it ?
They told me Inventor fusion is not an easy tool and would prefered to use inventor files.
Thank you
Subscription customers can run previous versions of their Autodesk software.
http://www.autodesk.com/subscription/licensing
Once you get your old version installed and running, you get to re-do all the IV 2014 work you have done so far in IV 2013.  Try to think of it as modeling practice and try to improve your technique and simplify your models.
*Expert Elite*
JDMather
Message 2 of 17 (8,933 Views)
Re: opening inventor 2014 files with Inventor 2013
09-19-2013 12:09 PM in reply to: belsebuth
File>Save Copy As>Type STEP (*.stp)
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Valued Mentor
Martin_Goodland
Message 3 of 17 (8,908 Views)
09-19-2013 01:14 PM in reply to: belsebuth
No, the only way your client can carry on working with the native Inventor files is if you move back to 2013 to do the work or your client upgrades to 2014. All the other options are work rounds that will loose any modeling history.
It is possible to save the 3d files as STEP which will give your client a 'dumb' solid but any drawings or documentation done for the project would need to be recreated from scratch by your client if they ever wanted to make a drawing revision.
Regards
Martin
PDSU 2014 SP1.3
Windows 7 64bit SP1, Office 2007 Pro
Intel i7 980x, 24 Gb DDR3 RAM
Geforce 760GTX Graphics (Diver 337.88)
256GB SSD OS, 80GB SSD working folder
Space Pilot
Member
belsebuth
Message 4 of 17 (8,861 Views)
09-20-2013 06:55 AM in reply to: belsebuth
Thank you for your answer.
Now this step files is crashing my computer's customer :smileysad: I have seen a topic about that, I will try to search the answer.
This lake of compatibility between inventor release is not friendly at all.
*Expert Elite*
mcgyvr
Message 5 of 17 (8,852 Views)
09-20-2013 07:19 AM in reply to: belsebuth
Its ALWAYS been like that.. And just about every other 3d cad package is the same way.. None are "backward" compatible due to the fact that new features could be added that the older version knows nothing about.
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Member
belsebuth
Message 6 of 17 (8,839 Views)
09-20-2013 07:55 AM in reply to: mcgyvr
I do understand the technical challenge that could represent the compatibility problem.
But try to be in my chair, we just bought a new software and invest lot of money for a small and new company so we don't have 2013, and our Customer who is a huge group did not upgrade yet to 2014.
And now we have a crisis issue cause of that.
So can we ask to Autodesk to give us a copy of Inventor 2013?
*Expert Elite*
swalton
Message 7 of 17 (8,838 Views)
09-20-2013 08:06 AM in reply to: belsebuth
Inventor 2014
Vault Professional 2014
*Expert Elite*
JDMather
Message 8 of 17 (8,829 Views)
09-20-2013 08:12 AM in reply to: swalton
swalton wrote:
.... re-do all the IV 2014 work you have done so far in IV 2013.
Or run Feature Recognition, or edit the solid body for only changes as needed.
tsreagan
Message 9 of 17 (8,829 Views)
09-20-2013 08:13 AM in reply to: mcgyvr
The problems behind backwards compatability are logical as mcgyvr has pointed out.
The only thing about this that defies logic,  is the lack of a "save as earlier version" option.
Each new release knows what is new,  it could simply leave out any new items that are incompatable (and give you these components in a list), and the other 98 percent of a project should be able to be exported and opened in an old version.
In Autocad 2014,  we can save an Autocad 2004 format file, some things are lost in translation, but most things export.
I don't expect you to be able to save out an Inventor 2010 from 2014,  but saving as 2013 from 2014 should be possible. ie.. One version back.  I don't think that is too much to ask for.  2 versions back would be great.
I know Autodesk wants you to upgrade right away, but with the economy the way it is, the policy is causing inefficiencies in the industry as people scramble to work together across company borders.
Software makers and content providers often don't consider the industry wide impacts of their decisions and policies.  Like model houses that don't spend the time to auto name the parts you download,  so 10,000 people have to name the part on their end.  Inefficient!!
This issue is one of my only and biggest issues with the Inventor series.
T.S.
*Expert Elite*
dgorsman
Message 10 of 17 (8,824 Views)
09-20-2013 08:15 AM in reply to: swalton
... also a good lesson in evaluating software prior to use, as well as ensuring proper communication with the client regarding software types, versions, file versions, and so on.  Best to get all that hammered out at the start of the contract with all parties knowledgeable about what can and cannot be done.
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Need installation help?
