When I previously opened an .sat file it was usually a solid gray color. Recently the .sat files open transparent and a gold color. I don't think I changed any settings. I've tried different files, and have the same results.All updates are installed. Any suggestions ?
Thanks, Larry
Solved by salariua. Go to Solution.
It comes in as composite or surface body. Change the options when importing the file or use sculpt to make it solid.
Thank you very much,
I selected the solid part option when opening, and all is well.I don't know how it was changed, I've been opening .sat files for years, and this has never happened. Catia files would open as expected, that's what really puzzled me.
Thanks again, Larry
