I'm pretty sure there is a solution for this somewhere already, but I just can't seem to find it. I'm writing a Select Case Rule, that chooses different assemblies to open, depending the value. Now, I understand you must take the 'Run Rule (with map)' setup, but I don't understand what to fill in so that it will open the Rule in the given map. Every time I try it, it says the file can not be found..
