I have a relativly basic ipt file in 2013 that I would like to open up in 2012 on another machine. I'm wondering if there's anyway I can open it up and edit it? It's kind of crucial and I assumed I'd be able to since the part used nothing besides the rudimentary tools that have been in inventor since the beginning...
Right now, I'm getting a "Database schema...which is newer than this version".
Thanks!
Solved by JDMather. Go to Solution.
Why shouldnt you have to specify the CSK angle? It allows more flexibilty in the design & its not a cause for problems.
Really dude, if you think Inventor is bad - and its not, its just as good as SolidWorks - try using Siemens NX, thats a whole new level of frustration.
I do not believe that any parametric softwares are backwards compatible. Maybe some one knows of a 3D software that I am not aware of that does. I also believe that this is by design and not because it is not posible. These companies just want you to keep buying there new products or by force.
is anyone aware of any parametric software that is backward compatible?
When software is unstable it is not the users fault. IT IS THE COMPANY's fault. THat would be the company that is selling it before it is perfected. Does that not make sense to anyone?
How about when you add a circle to be concentric to an existing circle or arc in sketch mode in solidworks.
All you do is select an existing circle and solidworks automatically knows that this new circle is concentric to it.
Inventor you have to
draw circle 1st
then go contrainsts
then slect the concentric button
then select an existing circle
Solidworks is simply more intuitive and at 1/2 the price.
WHY USE inventor?
Start the arc/circle on the existing center point? I really wish an admin would lock this thread.
Well, you could do all that ... but if you want to do it quick and easy, you'd just press the offset button, select your circle or arc, and then boom - concentric circle or arc.
Or you could just do it the hard way and complain about it. Your choice.
Rusty
Glad that I do not have to use nx. We have a Siemens software called teamcenter. Siemens did not create any software they just bought out existing companies. Siemens started as an electronic component company I believe.
Also inventor 2011 boasted as being the best teamcenter compatible 3D software in the world.
Only problem was it didn't work with teamcenter at all. Catia and Pro-E did just fine without bragging about it.
So autodesk was either falsely advertising or they have many people there whom suffer from mental disorders so severe that they cannot differentiate between reality and the fantasies in their heads.
Either way autodesk is not a company that I want to trust. I used to think autodesk was one of the best software companies in the world until they went to Autocad rel 13 (its 1st wondows release) in 1994. By the way THE UNDO COMMAND was created by autocad before 1990. How many companies have copied or stolen that wonderful time saver command?
Edited by
Discussion_Admin
@not2013 wrote:What if you have other entities connected to the exisitng circle? Then you have to delete them all.
Uncheck "loop select" and pick only the segments you want to offset? Or just start your new circle on the center point of the existing one?
Really, it's not that difficult. It's a poor craftsman that blames his tools.
Rusty
That doesn't always work, it sometimes goes to the centerpoint and sometimes does not. Then you have to go back and move it. But when inventor is not able to acknowledge centerpoints, endspoints and intersections due to it's unstable design then it becomes a whole new way of wasting time. It is faster and more secure to do it in solidworks. Solidworks has always been able to see and allow me to select them. It is stable, inventor is not.
Thats still an extra step dude, please recount? Again inventor cannot always understand centerpoint endpoints and intersections. In Solidworks I never worry about it. Inventor i'm always double checking stuff in sketch mode.
@not2013 wrote:That doesn't always work, it sometimes goes to the centerpoint and sometimes does not. Then you have to go back and move it. But when inventor is not able to acknowledge centerpoints, endspoints and intersections due to it's unstable design then it becomes a whole new way of wasting time. It is faster and more secure to do it in solidworks. Solidworks has always been able to see and allow me to select them. It is stable, inventor is not.
Is the circle you're trying to go concentric to in the sketch you're currently working on? The only time that Inventor doesn't snap to center / end / intersection points is if they're located in a different sketch. Or, of course, if you didn't actually click on the center / end / intersection points ... but that would mean user error, and you seem to be pretty much incapable of that.
Rusty
I never selected loop select to begin with. Why should I have to undo autocads selections? Why can't it just be easy?
Edited by
Discussion_Admin
@not2013 wrote:I never selected loop select to begin with. Why should I have to undo autowrecks selections? Why can't it just be easy?
If you turn it off, it stays off until you turn it back on.
As for easy ... I've got an easy button sitting right on my desk. You can't have it. Go to Staples and buy your own.
Rusty
Sometimes inventor does not work properly in those cases inventor does not reconize centerpoints, endpoints or intersections. It acts as if there is nothing in the sketch even though you may have a dozen or more intersections. It cannot reconize any of them.
Edited by
Discussion_Admin
Attach a part file that exhibits this behavior, and I'll fire up Camtasia and see if I can replicate it while recording.
Rusty
THEN STOP WINGING AND QUIT
