Inventor Forum
open gl setting on quadro 4 cards
6 REPLIES 6
99 Views, 6 Replies
since Inventor is not on the program lists on these cards, out of curiousity
what setting are you guys using? default? autocad...?
Brian Land
Mechanical Design
Lorik Tool Inc.
6 REPLIES 6
SolidWorks.
Dave Jacquemotte
Automation Designer
Isn't that a kick in the teeth?
I use the sw setting as well. Since the Nvidia cards and drivers are
on the approved list, which should help Nvidia sell more cards (not
that they need help in that area) shouldn't Autodesk be able to 'urge'
Nvidia to add an "Inventor" setting?
Eventhough it would be a settings that are probably the same as sw?
Jon Genova
Senior Mechanical Design Engineer
BioServe Space Technologies
A NASA Commercial Space Center (CSC)
genovaj@stripe.colorado.edu
Bioserve URL http://www.colorado.edu/engineering/BioServe/
Personal URL http://stripe.Colorado.EDU/~genovaj/
"Eventhough it would be a settings that are probably the same as sw?"
At least persuade nVidia to list it as SolidWorks/Inventor.
Oops, make that Inventor/SolidWorks. B-)
MechMan
I'm just using the default - ie: nothing is selected.
What will change in operation if I select something else?
"Brian Land" wrote in message
news:50321D06E3B476E69B619D90197D5BB7@in.WebX.maYIadrTaRb...
curiousity
> Brian Land
> Mechanical Design
> Lorik Tool Inc.
It should perform better in IV. With the 4345 drivers you HAD/HAVE to have SW
selected as App. or else you would get these weird ghost lines in IV.
Dave Jacquemotte
Automation Designer
I've never used SW or any other software selected in this setting and have
never had a problem (except for R6sp0).
"Dave J" wrote in message
news:B06E15C887E61BE55A1648A20FFD5B8B@in.WebX.maYIadrTaRb...
SW
> Dave Jacquemotte
> Automation Designer
