Somehow attachements don't work for me. Hereby i post the full code: Sub Main Imports Inventor.ViewOrientationTypeEnum Imports Inventor.DrawingViewStyleEnum Dim oDrawingDoc as DrawingDocument Dim oPartDoc as Document Dim oSheet As sheet Dim oTG As TransientGeometry Dim oView1 as DrawingView Dim oView2 as DrawingView Dim oView3 as DrawingView Dim oView4 as DrawingView ViewScale = 3/16 'Ask to create drawing? dwgQuery=MsgBox("Would you like to Create a drawing for this MODEL?", vbYesNo,"Drawing Selection") If dwgQuery = vbYes Then oPartDoc = ThisDoc.Document 'Define IDW Template File Location oDrawingDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "F:\Stage\Inventor\sheet metal3\Drawing1.idw", True) ' oDrawingDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "", True) oSheet = oDrawingDoc.Sheets.Item(1) 'Define 2d view bottom left corner points for four views oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(1, 1) oPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(1, 6) oPoint3 = ThisApplication.TransientGeometry.CreatePoint2d(5, 1) oBaseView = oSheet.DrawingViews.AddBaseView(oPartDoc,oPoint1, 3/16,kFrontViewOrientation, kHiddenLineDrawingViewStyle) oView2 = oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint2, kHiddenLineDrawingViewStyle, 3/16) oView3 = oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint3, kHiddenLineDrawingViewStyle, 3/16) End If End Sub
