Inventor General Discussion
Paul-tedecon
Message 1 of 8 (447 Views)
Accepted Solution
Open all parts in assembly at once
447 Views, 7 Replies
10-03-2012 06:39 AM
Hello all,
is it possible to open all parts in an assembly at once?
I tried to select them all in the modelbrowser, and then open, but ain't working. I tried also with the design assistent, but also not working.
I will use this function to place all (open) parts from an assembly in one drawing. Then i am sure that i don't forget any parts.
Or is there maybe another solution for my problem?
Thanks in advance,
Paul van Deursen
Hi Paul-tedecon,
As others have mentioned, the practice of placing all of your model drawings into a single drawing file is often poor practice. But here is a simple ilogic rule to open all of the referenced files from the assembly.
'Define the open document
Dim oDoc As Document
oDoc = ThisDoc.Document
'Look at all of the files referenced in the open document
Dim docFile As Document
For Each docFile In oDoc.AllReferencedDocuments
'open the indexed file
'true opens the file normaly
'false opens the file programatically without generating the graphics
ThisApplication.Documents.Open(docFile.FullFileName, True)
Next
 I hope this helps.
Curtis
*Expert Elite*
Cadmanto
Message 2 of 8 (430 Views)
Re: Open all parts in assembly at once
10-03-2012 07:21 AM in reply to: Paul-tedecon
Paul,
How many parts are we talking?
What is your final drawing wanting to look like?
This might be a candidate for an ilogic rule.
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
Paul-tedecon
Message 3 of 8 (412 Views)
10-03-2012 08:28 AM in reply to: Cadmanto
Thanks for your reply.
We’re talking from 10 to around 90 parts and all assemblies are different (totally different).
I want a front and maybe sideview from each part on one drawing. For this customer we need to export all parts to autocad, place them on one sheet and dimension all parts following their dimension style.
A tool to automatically open all parts, will already safe a lot of time, then I only have to place them in a drawing.
Hope this gives an answer on your question?
This is actually the first time I hear something about ilogic rules. What will it do?
Thanks!
*Expert Elite*
JDMather
Message 4 of 8 (397 Views)
10-03-2012 08:56 AM in reply to: Paul-tedecon
Just to clarify - this is all parts on one drawing sheet in one dwg file?
Not multiple sheets (one per part) in one dwg file.
Not multiple dwg files (one per part).
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Paul-tedecon
Message 5 of 8 (353 Views)
10-03-2012 11:43 PM in reply to: JDMather
Indeed, all parts of one assembly on one sheet exported to dwg.
Unless there is not enough space on a sheet, but then i will make another dwg with the rest of the parts on it.
Thanks!
Distinguished Contributor
R.Corriveau
Message 6 of 8 (322 Views)
10-04-2012 09:31 AM in reply to: Paul-tedecon
You can open multiple parts from explorer but not the assembly browser.
IMO: That many parts detailed on one sheet is a bad practice.
*Expert Elite*
harco
Message 7 of 8 (311 Views)
10-04-2012 11:13 AM in reply to: Paul-tedecon
You can export the bom to excel and use as a checklist.
You could also pack and go the assembly to another folder to gather all parts in one place.
You could add a custom iproperty to all the parts and show in the BOM editor, when the part is included in the drawing fill in the iproperty with yes,done, drawn...etc. as an alternative checklist.
One thing I wouldn't do is open 90 individual parts at once, my machine would choke after about 30.
Yours may be a super duper machine.
I normally only open about 10-20 if it's necessary to do common action on them all.
I know the customer is always right even when they are wrong, we have them asking for all parts on one drawing too, but I agree with the other lads, too many parts on one drawing is asking for trouble.
A final option would be view reps in the assembly to isolate the parts in the drawing, but this is time consuming.
*Expert Elite*
Curtis_Waguespack
Message 8 of 8 (303 Views)
10-04-2012 11:49 AM in reply to: Paul-tedecon
Hi Paul-tedecon,
Next
 I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Need installation help?
