Hi, I need to create a cube, made of a open cell metal foam. It is really hard to made this manually. So is there any function to create such a material (with a random generator or a structur generator)? I attach a picture of the material which I need as a 3D model.
There is no need to create second cube.
Simply Extrude - Cut a square by disance equal to side.
If you really want to use two cubes -
you can use Move Body and Combine - Cut
or
Derived Components.
I recommend that you first go through the built in Help>Learning Tools>Tutorials and Skill Builders
and then
attach your attempt here.
The process you desribe (of cutting one cube from another) would not result in geometry that matches your original image.
Has your design intent changed?
