Inventor Forum
Opeing Solidworks assembly file in Inventor, parts gets unconstrained !!
13 REPLIES 13
Message 1 of 14
1236 Views, 13 Replies
When i try to open up Solidworks assembly file  (SLDASM) in Inventor, why does all the parts gets unconstrained? Those files are constrained in Solidworks but some where in the transition, things get unconstrained. is there a quick fix for this?
Thanks  !!
13 REPLIES 13
Message 2 of 14
RobJV
AFAIK, no 3D CAD software will allow you to keep constraints when exporting from one product to another.  No fix is available.
Message 3 of 14
in reply to: RobJV
Well that sucks !!! Thanks for you response.
Message 4 of 14
Curtis_Waguespack
Hi Aventador2011,
Typically when working with translated assemblies, I'll just ground all of the imported parts in place so they won't move, and then unground and properly constrain the ones that are intended to move, or that need to be modified.
I hope this helps.
Curtis
Message 5 of 14
That should be a defaulted-on user switch when opening non-native assemblies: ground everything, so it's not like a hand grenade going off.
KState92
Inventor Professional 2020
AutoCAD Mechanical 2022.0.1
Windows 10 Pro 64 bit - 1903
Core i7-8700 32 GB Ram
Quadro P2000
Message 6 of 14
AustinLiu
in reply to: kstate92
Thanks all for your feedback.
The solution in the future should be "to keep the constraints in data translation", but "setting all grounded" is not the direct solution from my perspective. Since we can choose all components and set them all grounded together and it's very straightforward to achieve, I am not quite sure how useful such an option should be...
-Austin
Austin-Zongjie Liu
Zongjie.Liu@autodesk.com
Software Quality Assurance Manager
Design, Lifecycle & Simulation
Message 7 of 14
in reply to: AustinLiu
FYI
the ground & root tool from the productivity menu is flawed
Not only does it ground your parts, it adds flush constraints to the parts origin planes, this will add huge overhead to your file sizes.
Message 8 of 14
JDMather
I like your perspective - let's see you do it though.
Message 9 of 14
AustinLiu
I agreed.
Actually I didn't try to set all grounded, but only for those I needed when want to set constraints to them.
This is one of the reasons that I don't think need to add such an option.
-Austin
Austin-Zongjie Liu
Message 10 of 14
AustinLiu
in reply to: JDMather
Hi JDMather,
You are the mentor to me on this forum and some Inventor functionalities too especially on data translation; personally I learn a lot from you. 🙂
Thank you.
For the constraints, users need them during data translation, but we still need more time to plan for this in the future.
Back to the question about the option for "set all grounded", how do you feel this option would work for users if Inventor suppots it? Have you, or someone else you know, ever met any problems and then want such an option?
We want to hear more feedback from our customers and Inventor experts.
Thank you so much for your help on this topic, and this forum.
-Austin
Austin-Zongjie Liu
Message 11 of 14
JDMather
This is what I am interested in, "The solution in the future should be "to keep the constraints in data translation".
Pull that off and you will have at least one advantage over competitors.
Message 12 of 14
AustinLiu
Thanks. I will pass on the information to our development team.
Austin-Zongjie Liu
Message 13 of 14
hoser_71
We could use a Ground All components when importing a file.  We have to import files all of the time from STEP, Rhino, SAT, DWG, and Solidworks.  Usually the imported components are reference, so I don't need the constraints.  We have had people import a model, not ground the components, and accidentally move a component out of place while working on it.  The movement isn't caught right away, and we wasted a lot of time trying to figure what went wrong when we finally caught the mistake.
I'm thinking it could be a check box in the Options dialog when importing.
Joe Bartels
Message 14 of 14
Curtis_Waguespack
Hi everyone,
Here is a quick iLogic rule to ground all components  that can be used when importing models from other modelers.
I hope this helps.
Curtis
' set a reference to the assembly component definintion.
' This assumes an assembly document is open.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'set the Master LOD active
Dim oLODRep As LevelofDetailRepresentation
oLODRep = oAsmCompDef.RepresentationsManager.LevelOfDetailRepresentations.Item("Master")
oLODRep.Activate
 'Iterate through all of the occurrences and ground them.
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
'check for and skip virtual components
If Not TypeOf oOccurrence.Definition Is VirtualComponentDefinition Then
oOccurrence.Grounded = True
else
end if
Next
