Inventor General Discussion
Member
0 Kudos
Post 1 of 4
One part multiple lengths?
322 Views, 3 Replies
06-25-2012 02:12 PM
Hello, hoping someone can help me out. I'm creating an assembly and in this assembly I need to add some foam pieces. These pieces are the exact same part number but can vary in length. How can I make such a part so that i can insert it into an assembly multiple times but have different lengths? I'd rather not make multiple pieces of foam for every single assembly for all of our product lines and am kind of loooking for the "one foam to rule them all" option. I would assume this would be an ilogic component I would have to create, but i haven't really made a part like that yet. Any advice would be appreciated. Thanks in advance
*Expert Elite*
2,129 Kudos
Post 2 of 4
Re: One part multiple lengths?
06-25-2012 03:20 PM in reply to: jfildes
You can do this with an iPart without having to getting into iLogic.
Could probably do it with Frame Generator custom profile as well, but that takes a bit more knowledge.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Member
0 Kudos
Post 3 of 4
06-26-2012 06:03 AM in reply to: JDMather
Thanks, I figured something along those lines would work but wasn't sure how. Now I have my iPart and am able to enter a custom length when i place the part and it shows up in the BOM as the correct part number. is there an easy way to have it display the length in the BOM instead of the count of 1?
Product Support
7 Kudos
Post 4 of 4
07-10-2012 12:51 PM in reply to: jfildes
You can change the properties of the BOOM to reflect the G_L (length) value instead of the occurrence. There are many explanations out there on how. Here's one: http://inventortrenches.blogspot.com/2011/03/understanding-autodesk-inventor-frame.html
Dave Anderson
Premium Support Analyst – DLS Mechanical Design
Autodesk, Inc.
If I have answered your question, please "Accept Solution" so others may benefit as well.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
