Inventor Forum
One part multiple lengths?
3 REPLIES 3
jfildes
1442 Views, 3 Replies
Hello, hoping someone can help me out. I'm creating an assembly and in this assembly I need to add some foam pieces. These pieces are the exact same part number but can vary in length. How can I make such a part so that i can insert it into an assembly multiple times but have different lengths? I'd rather not make multiple pieces of foam for every single assembly for all of our product lines and am kind of loooking for the "one foam to rule them all" option. I would assume this would be an ilogic component I would have to create, but i haven't really made a part like that yet. Any advice would be appreciated. Thanks in advance
3 REPLIES 3
JDMather
in reply to: jfildes
You can do this with an iPart without having to getting into iLogic.
Could probably do it with Frame Generator custom profile as well, but that takes a bit more knowledge.
jfildes
in reply to: JDMather
Thanks, I figured something along those lines would work but wasn't sure how. Now I have my iPart and am able to enter a custom length when i place the part and it shows up in the BOM as the correct part number. is there an easy way to have it display the length in the BOM instead of the count of 1?
dave.anderson
You can change the properties of the BOOM to reflect the G_L (length) value instead of the occurrence. There are many explanations out there on how. Here's one: http://inventortrenches.blogspot.com/2011/03/understanding-autodesk-inventor-frame.html
Dave Anderson
Sr. Support Engineer– CAM
Autodesk, Inc.
