I have used AC 2000 for the last 10 years. I just landed a job at a metals fab company that uses Inventor Pro 2012. I am completely lost. Can I change the settings to revert back to the old AC 2000?
Solved by mrattray. Go to Solution.
Solved by JDMather. Go to Solution.
AutoCAD is not Inventor.
Inventor is not AutoCAD.
Which one do you want (have) to use?
If you have Inventor 2012 I think you also have AutoCAD (I think they came as a package back then), but I would concentrate on learning Inventor. (you won't recognize AutoCAD 2012 either, but it could be set to Classic)
