I had a similar error today. I had 2 instances of a sub - one being
adaptive.I constrained both of them fine until the adaptivity had to come
into play. Crash after crash. I finally ended up deleting the constraints
on the adaptive sub, and fully constraining the non-adaptive sub(it adapted
the way I intended the other to adapt??!!?). I tried to reconstrain the
other - and poof crash. I turned off adaptivity on the one sub and
constrained it the way it should have to start with. I didn't need the subs
to move, I just needed them to line them selves up for constraints. Go
figure.
Cory McConnell
BJ Pipeline Inspection
"Brian Corbin" wrote in message
news:5047F8B90A791B66B8CA2957E7D64337@in.WebX.maYIadrTaRb...
> I can make this work in 5.3 but not in 6 can someone else please try.
> I have an assm of a hyd cyl that I drop into an assm. Constrain it into
> place and make it adaptive so I can drive the constraint on the piston to
> make the cyl assm move another assm (non adaptive) That part works fine.
Now
> I drop in another copy of the same cyl, BEFORE I place any Assm
constraints
> if I drive the other assem the piston comes out just like it should. But
If
> I assm just ONE end of the new cyl onto anything then try to drive the
other
> piston I can a connot solve at or near this location error.
> Basically in 5.3 I could (and did all the time) use the same cyl many
times
> in the same assm to drive lots of different bits but I cant seem to in 5.3
> Brian
