Inventor General Discussion
*Hamilton, Jake
Post 1 of 9
Offset work plane
159 Views, 8 Replies
06-26-2003 11:41 PM
Is there a way to offset a plane from an origin plane?
Jake Hamilton
Doulos Enterprises, Inc.
616-464-3334 Ext. 2#
Distinguished Contributor
0 Kudos
Post 2 of 9
Re: Offset work plane
06-26-2003 11:44 PM in reply to: *Hamilton, Jake
I believe you can just select the workplane feature, highlight the origin plane in the browser and then drag in the graphics area. It may be easier to turn on the origin planes visibility so that you can just pick it when the wp feature is active though.
*Caldwell, Larry
Post 3 of 9
06-26-2003 11:48 PM in reply to: *Hamilton, Jake
Think you can pick the workplane tool, pick the plane/face to offset from
and drag while LMB is down. An offs distance dialog should pop up allowing
you to enter a distance. Also, if you pick the workplane command and hit F1
you can get a pretty good handle on workplane creation.
~Larry
"Jake Hamilton" wrote in message
news:C1DD395D3A17FD143CBB66FD15CAAEC1@in.WebX.maYIadrTaRb...
> Jake Hamilton
2 Kudos
Post 4 of 9
06-26-2003 11:50 PM in reply to: *Hamilton, Jake
Yes. If you click on the workplane tool and then hit F1 and how to create offset workplane it says (and animates the process)to select and drag the workplane you want to offset to the desired offset distance. You can enter the distance directly if it doesn't snap to your desired distance. J.D.
*Hamilton, Jake
Post 5 of 9
06-27-2003 12:02 AM in reply to: *Hamilton, Jake
I clicked the work plane tool button, then the origin plane that I wanted to
offset from, and the offset dimensin dialog box came up.
Piece O' Cake
Just needed help finding the knife to cut it with :smileyhappy:
Thanks guys.
> Jake Hamilton
*Ham, Teun
Post 6 of 9
06-27-2003 12:16 AM in reply to: *Hamilton, Jake
Sure, first make your Origin Plane visible, than create a Work Plane by
selecting and dragging the Origin Plane(s). You can enter positive or
negtive values (which can not be done with dims)
news:3D868FA727EBD2DAA4394CDD6CCAE72B@in.WebX.maYIadrTaRb...
> Oops, wrong group. If you have an answer though....
> news:1EFADD2FA216C74FE6E6784505A7BFFC@in.WebX.maYIadrTaRb...
> > Is there a way to offset a plane from the origin planes?
> > Jake Hamilton
*Caldwell, Larry
Post 7 of 9
Re:
06-27-2003 01:39 AM in reply to: *Hamilton, Jake
If you RMB on that plane in the browser and pick "Show dimensions" the
dialog will pup up again and you can change the offset, and any geometry
that is sketched on that plane.
~Larry
news:014A9CF9CD40B2294291EEABB42F8300@in.WebX.maYIadrTaRb...
to
> Piece O' Cake
> Thanks guys.
> > Jake Hamilton
*boettger, Kent
Post 8 of 9
06-29-2003 05:52 AM in reply to: *Hamilton, Jake
But be aware off the workplane bug.
if you make a workplane adaptive and then try to clear the adaptivity the
workplane gets groundet and then ist as far as i know no way to edit the
dimension on the
workplane anymore ( redo all or undo undo undo undo ). another "bug" they
newer stop :smileysurprised:(
anyone have a solution on this i would like to know.
> Jake Hamilton
*Caldwell, Larry
Post 9 of 9
Re:
06-29-2003 05:58 AM in reply to: *Hamilton, Jake
If you don't want the workplane grounded as would be expected when
adaptivity is turned off, you can use the redefine feature to bring it back
to a normal workplane.
~Larry
"Kent boettger" wrote in message
news:F0F81B3E13BC35682ED09C8FA2E42550@in.WebX.maYIadrTaRb...
> dimension on the
> > Jake Hamilton
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
