I am in sketch mode.
I create two lines(.25) up and then .25 over. I create a fillet of .250. Then I can not offset the fillet. It says
"can not offset beyond this point"
What is the reason behind this?
update: I can offset trimmed circles to my .250 radius/fillet but still not one i filet?
Are you offsetting inside the arc to a value larger than the arc's radius?
Hi jbelle7435,
As a rule of thumb, if you wait to place your corner radius fillets as features and not in the sketch, you will find your Inventor models will work out better. Keeping your Inventor sketches as simple as possible is generally the best practice.
Inventor 101: Simple Fully Constrained Sketches
http://inventortrenches.blogspot.com/2011/03/inventor-101-simple-fully-constrained.html
I hope this helps.
Curtis
Edit: Doesn't look like the others actually tried your steps.
Not sure why you would do that, but try this.
1. Edit the radius dimension to .125.
Can you offset now?
Change it back to .25
Where are the lines? They are still there, right? (see step 1) But zero length.
How would zero length entities be offset?
Q. What is the expected behavior?
Now try this:
Start the Offset command but unselect Loop Select.
Select your arc and RMB Continue.
Now you are not selecting the zero length lines so it should work.
See Tips 35 & 36 http://home.pct.edu/~jmather/AU2006/MA13-3%20Mather.pdf
(from 7 years ago).
JD got it correct.
The issue is with a zero length line.
Have a Happy Halloween.
