Inventor Forum
Offset in Sketch
4 REPLIES 4
804 Views, 4 Replies
Offset in Sketch
Im sure this is a simple solution, but I cant figure it out. On my computer at work, if I use the offset feature (2D sketch) I get a different result than I do on my home computer. For example. If I draw a rectangle and then offset that drawing and dimension it .75, all it takes is that one dimension to constrain the entire offset. On my work computer if I offset that same rectangle, I have to go dimension each line. I can find a way to change the "rules" of that feature. Thanks
4 REPLIES 4
dan_inv09
Right click before you place it and "Constrain Offset"
in reply to: dan_inv09
Thanks. Kind of a self taught guy here, outside of learning the complex stuff from the masters on here.
dan_inv09
Actually anytime between when you click the offset icon and when you place it you can change that.
A little tip for people learning Inventor - try right clicking, lots of good stuff is hidden there. If you think, "It would make sense that if I'm doing this I could ..." it's probably there if you right click.
good point!
Sincerely,
Aaron Vogler
Vogler Metalwork & Design
ph-812.615.0042
fx-812.615.0171
aaron@voglermetaldesign.com
